"Yes, your 110 lacks the displ
"Yes, your 110 lacks the displacement to really produce more than the 110 horses it's putting out now.
The 110 powerhead was shared with the 90 and 100 horse. The 110 was the max for the 99.6 cubic inch (1.6 litre) powerhead in use.
The 120 and 140's shared a 110 cubic inch (1.8 litre) head which still actually is kinda short on dispacement to be cranking out 140 horses.
In the 86 model year, the 110 is a cross flow, the 140 is looper, the bore is the same but the stroke is different etc etc etc.
Anytime that the horspower exceeds the displacement, the life of the powerhead is reduced. Motors just don't like to produce more horses than they have cubic inches. A ratio of 1:1 or less is ideal for long motor life. That's why modern high horse engines are often rebuilt long before they see their 10th birthday. When you are cranking 225 horses out of 150 cubic inches sooner or later the stress is going to cause something to let go....
And if even if it could work, which it wouldn't, going from 110 to 140 horses would net you a result of approx 2 more mph under perfect conditions, but would burn 20-30% more fuel "all the time". Not worth the cost even if it is viable to do....
To get a "noticable" performance difference you would have to move up to at least 175 horses or more. For every 50% increase in horsepower (from your current) you can expect 6-7 mph increase at extreme top end.
You could improve your hole shot moving from a 4 cylinder to a 6 which would give you a better torque band.
Any given boat tends to perform at it's peak when fitted with an outboard that is 80% of the max rating for the boat. Adding more horsepower past that point almost always results in more gas burned with very little, if any, noticable performance increase. Any given hull will have a max speed regardless of what you hang on the back of it (and still operate in a stable fashion). If you are fitted correctly, enjoy the boat - besides, you can probably rebuild your carbs 4 or 5 times for the cost of a new pair
