Carbs to EFI?
You need a whole lot more than just the manifold. You would also need the entire ignition system including the wiring harnesses. EFI models are computer driven unlike the carb models. The have the computer, crank position sensor, throttle sensor, map sensor, air sensors and I'm probably missing a few.
If using the parts from a similar model year XRI model, it should all fit but it would be a massive job and unless you were getting the parts for nothing, it would significantly deplete your wallet.
It would be easier and probably cheaper if you swapped out the entire powerhead if you have a donor motor.
