CARBS AND FUEL EFFIECENCY
D
Dean Travis
Guest
Will the newer Edlebrock 600 c
Will the newer Edlebrock 600 carbs give better GPH over the older carbs? Even rebuilds? The Edelbrocks are a relatively cheap upgrade if they will better the fuel effiecency.
Dean
"Hard to tell if you'll se
"Hard to tell if you'll see measurable GPH improvement with the new carb based on its design; depends on how "sloppy" your old carb was. Keeping away from WOT, having the right prop and keeping the boat light all contribute to the equation."
..."Will the newer Edlebro
..."Will the newer Edlebrock 600 carbs give better GPH over the older carbs?"
I'll let you know in a few weeks! Installed oneover the winter but haven't had her out yet.
Jeff
"Jeff,
I put a Edelbrock 60
"Jeff,
I put a Edelbrock 600 (1409)on that I bought from Jegs. Ran it through the entire range. Wow I'm impressed. I have fuel meters on each engine and the results are there. Its better! Its only a few gallons per hour across the entire range. Going away the closer you get to WOT. But hey if I do both engines its significant! Definately worth it!
Dean"
