Carb
easy
"SHOULD GAS COME OUT THE FRON
"SHOULD GAS COME OUT THE FRONT OF CARBS WHEN PRIMER IS PUMPED UP TIGHT ? AND WOULD THIS CAUSE HARD START,AND ALSO WHAT IS THE PLUG GAP? 1982 MARINER 50 HP. 4 CLY. ANY INPUT APP."
No gas should come out like th
No gas should come out like that. You need to rebuild your carbs. The std plug for that motor is NGK BUHW-2 which you do not gap.
"IBNFISHN Thanks, would the ga
"IBNFISHN Thanks, would the gas be passing the needle or gaskets ? I have new gasket set for it but thats all .if u can turn carb up side down and cant blow air thrue does this show niddle is ok seal ?"
