carb rebuild part #
boatbo
Trying to find part# for carb rebuild kit for. Merc 5.0 TKS 2008 2bb. chaparral. Engine serial # 1A318085.
Carb has 2 #'s on the body. 8M2003946 (I think it's a six hard to read could be an 8). Other # 31 7Y09.
The kit is on the very bottom of the following links for you,
http://www.marineengine.com/parts/mercury_marine_parts/sn/1A318085/4M11025UU/12834_80
https://www.perfprotech.com/mercury-marine-parts-catalog/carburetor/assembly/12834/80?umodel=1440
http://www.ebay.com/sch/i.html?_odk....TRC0.A0.H0.TRS0&_nkw=3302-804844002&_sacat=0
CARB. REPAIR KIT 3302-804844002 3302-804844002
3302-804844002OEM Part 3302-804844002 - Carburetor Repair Kit (more info) About Mercury Marine $72.92 $72.92 Add to shopping cart
Available to order:
Usually ships
within 8 days
Aftermarket Sierra Carb Kit 18-7098-1
18-7098-1OEM Match 18-7098-1 - Carburetor Kit, 3302-804844 (more info) About Sierra Marine $67.10 $52.14 Add to shopping cart
10+ in stock.
Here's your complete parts catalog for this engine model,
https://www.perfprotech.com/mercury-marine-parts-catalog/umodel/1440
You are also going to want to order Merc part number 91-866201 so you can adjust the Idle mixture screw once you follow the directions within the small TKS Carb service manual number 41, Merc part number 90-866202 that you should consider buying as well, http://www.ebay.com/sch/i.html?_odk...C0.H0.X90-866202.TRS0&_nkw=90-866202&_sacat=0
http://www.ebay.com/sch/i.html?_odk....H0.X91-866201+.TRS0&_nkw=91-866201+&_sacat=0
Or a fuller version OEM service manual 90-864260T00
7Y09 is the date code the carb was made. November 9th 2007.
8M2003946 is the carb part number. http://www.bing.com/search?q=8M2003946&form=IE10TR&src=IE10TR&pc=EUPP_DCJB
