M
Mechanically-Challenged
Guest
"Ok,I got the manual and kit a
"Ok,I got the manual and kit and I am about ready to try and rebuild my first carb. I was reading the manual (Clymer) and it said Do not soak carb castings in carb cleaner. Now, does this mean I am not to soak the carb in a bucket of cleaner to clean it before rebuilding? Maybe I don't know what a casting is, but I am under the impression that it is the "body" of the carb.
If I don't soak it, how am I supposed to clean this thing before I rebuild it? Do I just spray EVERYTHING with can carb cleaner and rinse and dry thoroughly?
Question 2: I says "remove high-speed jet from float chamber with a fixed jet screwdriver (part No. 317002) or equivalent". Do I need a special tool to remove the jet or what else can I use?
The rebuild doen't sound too difficult, but since it is my first time, I want everything in place before I do it so I don't screw it up. I am sure I will be asking more dumb questions as I go through the engine "Synchronization and Linkage Adjustments" stage of the game, but that's enough for now.Thanks in advance for your help."
