"After the Edelbrock vs. Quadr
"After the Edelbrock vs. Quadrajet posts earlier, I changed out the poorly running/flooding Qjet with a new Edelbrock 1409. Of course all the adjacent stuff- breakerless ignition module, rotor, coil, plugs, I changed earlier when I was having problems with the Qjet. ANYWAY put on the new 1409 and fired the engine up. Took a few minutes for it to clean up but started running much better. Set the idle to about 800 RPM. All seemed pretty good. Went to adjust the mixture screws and ran into almost the same problem I had with the Qjet. I can run the screws all the way in and the motor idle doesn't change???? I ran the boat down the river and it seemed to do pretty well. Just to recap the set-up, I have twin 1989 270hp 350ci Crusaders FWC in a 29' Luhrs. I'm actually taking a few days off this weekend before I pull out what hair I have left. Any of you gurus have any ideas? I figured a new card shouldn't be leaking fuel from anywhere to bypass the mixture screws and let the engine still run. When I get back, I'm going to put on a vacumn gauge and do a few tests, do a full compression test, and check intensity of spark. Any other ides would be GREATLY appreciated! Thanks!!!!"
