1992 mercruiser 454s rochester carb loading up i have done these and they seem to work fine. i went through this this one found no plugged holes new kit and new float i checked the float that was in there about 11/32inch seemed close to chart.set the new float about the same i was able too match gaskets as the kit i got fit a few carbs ck all holes seemed fine put carb back on still loading in front jets. also new needle and seat power valve seemed fine not sticking any ideas before i take it apart again i am going to hook up and out board can to it and see if it leaks on bench? or just when its running thanks bcclew
[h=1][/h]
[h=1][/h]
