You guys have always been VERY
You guys have always been VERY helpful in the past and I appreciate it. I've got another dilemma:
Like the title says - this is about a 2007 Tohatsu 6.
I own the 6HP Nissan version (2008) of this motor myself and have put a 6HP carb on another 4HP Tohatsu(2007) in the past - Worked fine by the way.
This is a friends motor that has about 5 hours on it if that. About a year ago he went to use it for about the third time and it "wouldn't start". He let it sit in his shed till now when he finally brought it over for me to look at it.
While I set it up in my test tank(5 gallon bucket under the stand) - I noticed the kill lanyard was missing.
Put the one off my Nissan on it and it busted right off.
Then I notice it was blowing fuel out of the carb overflow. AKA the float was sticking.
Pulled the carb off and removed the bowl.
Now for the question: How does the float come off???? I need to clean the float-valve. The seems to be no obvious way to get it off. The float "axle" doesn't look like it slides out like in most carbs I've seen.
Another question since I'm gonna be maintaining about three of these motors: Is there some trick to the inside bolt that holds the carb on? The long 10mm one w/a phillips head??? I've been able to get it off each time but I keep thinking I'm missing some trick-tool that makes it easier.
Oh and ONE MORE question: Does anyone know what comes with the repair kit? I assume the float doesn't???
