K
Kent Bloomquist
Guest
" So far on this engine, I hav
" So far on this engine, I have replaced thermostat and get a running temp of about 140, replaced spark plugs, replaced fuel lines and bulbs, removed lean/rich linkage on idle screws per mechanics suggestion. Adjusted carb/timing sync and carb/carb sync per manual. Ran a bottle of OMC fuel system cleaner. Set idle screws out 5/8 turn per manual. Engine idles, but I get a slight flow of raw fuel out the throats of the carbs at idle, enough to drip off of bottom of air silencer housing maybe every ten seconds or so. Hadn't noticed before, because always had silencer cover on. "
