Carb 86 Evinrude 6hp
stubjones
"I'm going to rebuild the
"I'm going to rebuild the carb and fuel pump on my 6HP Rude, and I was wondering if there was any other parts needed, or recommended other than the Kits? Didn't know if I should get a new float, or other parts?
I'm going to order new spark plugs, and go ahead and get a water pump kit for future.
Any help advice is apreciated. Thanks Scott"
"unless damaged,float will be
"unless damaged,float will be ok...while u r wking on it,i would inst that pump kit...chg lower unit oil..make sure that carb,is spotless through out..make sure,u inst the correct top,gasket."
"the lil plastic part,in carb,
"the lil plastic part,in carb,..ck it,for any sign of a crack,along the sd of lil nozzle...very common,be sure to repl the rubber tube,and make sure,all those items,are clear..orientation,in the carb of plastic part,as well as oval gasket in bottom,..alll very important...complicated carb,for a 6 horse...huh.."
"I've changed the lower un
"I've changed the lower unit oil, and was able to get it to run long enough by feeding gas oil mix directley into air silencer to see the water pump was working well. This plastic part and rubber tube you speak of, are they part of the carb kit or something I need to purchase seperately? Thanks Scott"
"sierra is fine...i have'n
"sierra is fine...i have'nt used mallory..the plastic piece,if needed,is ordered sep...rubber tube,in carb kit."
