FishingLane
Engine will tilt up all the way, but will only go down 3 inches. This is an improvement from only about a half inch when problem started. I had the engine all the way up for over a week while a was replacing the impeller. When I completed the impeller job and tried to lower engine the problem started. When the engine goes down about 3 inches, it appears to be trying to continue and travels back up about a half inch when down switch is released. I have tried at least 4 bleeding cycles with no change. Using the manual release does not allow engine to drop. Any suggestions?
