pedalyurassoff
I am old enough to know to ask for help BEFORE grabbing a bigger hammer. This box is for my 1974 johnson 85hp outboard. It is a Powershift II, with the start lever below the main throttle handle. and a friction knob, and some other adjustment knob on the forward end of it, with the ignition switch, and an electric choke intermittent switch below that . I started having issues a few days ago with getting the starter to crank. I have noticed that the ignition switch is loose, and I think a wire has broken off inside. I was wiggling the start lever (high idle) and it would crank, but now nothing. The motor runs great. I can easily rope start it. Sooo, I got the start lever off, the three screws of the lower part of the cover, and that cover off. The throttle handle is off, but i can't seem to pry apart the two halves. The whole box is bolted to my railing from inside the upper part of the box...with only threads showing on the other side of the railing, so I can't detach it from the boat yet (it's a pontoon). What am I missing, here?
