I have a 1984 Mercury 75 hp 4 cyl. Bought this boat as a project and I am learning. It runs fine at idle. In gear it gets up to about half throttle and starts to bog down. By covering the air intake on the top carb it starts to gain rpm. I am no mechanic but here is what has been done. Stator has tested fine on the ohm test. The timing was a bit off and I think that the person before me thought they may have been adjusting the idle when in reality they were adjusting the spark advance. I could not get the required 23 for the max timing so to the screw being bottomed out, no more room to go. It is floating around 27 BTDC. Could this be because i can't achieve the proper rpm? I found out today that the person that rebuilt the top carb never took the core plugs out. I did clean a spider out of the needle and am wondering if there is a way a part of it got logged up in their somehow? The second issue is that I would adjust the idle mixture screw on the carb and it would not respond the way the service manual said. Two three turns and nothing. I would lightly bottom out and it would start to bog down and I tried many times slow, fast, half way in-between and it was not responsive. Any information would be greatly appreciated again. I have rebuild the fuel pump, replaced all gas lines and filter.
