"Take your best shot.
351 pc
351 pcm(ford), raw water cooled.standard rotation engine will not go above 2300 rpm under load. Rarely if wide open throttle it will take off suddenly(out of nowhere) but as soon as you throttle back a hair its back to 2300.
heres what Ive done so far:
new filters and water seperator
new plugs
new dist cap
new rotor
new wheels(nothing bound on the shafts)
new coil
rebuilt carb(holley 600)
swapped carbs
new risers and manifolds
swapped fuel lines with other engine after the seperator
swapped fuel lines at the pick ups on the fuel tank
new plug wires
new fuel line
nothing has made a difference.
since changing the manifolds and risers(it really needed that) engine runs warmer and pumps a less. pulled all hoses from seacock to circulating pump and they are clear. even blew out the oil cooler. pulled raw water pump tonite to check splines
why am I running hot now?
but most important, why are my rpms low?"
351 pc
new plugs
new dist cap
new rotor
new coil
swapped carbs
new plug wires
new fuel line
