CANT GET LU TO SLIDE ON
lee
TOOK OFF LOWER UNIT CHANGED I
TOOK OFF LOWER UNIT CHANGED IMPELLER SLID ON FORGOT WATER TUBE SLIDE OFF NOW WONT GO ON.
ANY IDEAS
" Lee, Make sure the spline o
" Lee, Make sure the spline on the driveshaft is lined up with the spline on the crankshaft. Turn the flywheel while installing the LU and after you feel them line up, the LU will move closer to the installed position. Also, sometimes the shift shaft needs to be aligned slightly. "
