snookwhaler
Engine is a 1983 Johson 35 HP
Engine is a 1983 Johson 35 HP long shaft. Engine is a tiller setup with thru hub exhaust (not the old style).
I was trying to pull my lower unit to replace the water pump yesterday with no luck... Am I missing something? Here is what I did:
1.) Removed screens and disconnected shift linkage.
2.) Removed 4 bolts going into bottom of motor shaft.
3.) Removed nut and washer from top of motor shaft.
The stud sticking up through the lower motor shaft looked a little corroded but not too bad. I soaked the thing with some Blaster and could get it to wiggle but it would not drop down more than about 1/8" in the rear and was still a little tight in the front.
Does anyone have any advise on seperating the lower unit from the engine without damaging anything?
