jawbreaker
"on my 2000 25 yamaha 2 stroke
"on my 2000 25 yamaha 2 stroke noticed that fuel was leaking out of the top left bolt on the fuel pump when i pump the bulb on the fuel line.I replaced the outermost gasket the diaphram and the innermost gasket and it still leaks. if it leaks when i pump the bulb then it proably is sucking air into the carb. bowls as well, I would have to think effecting the float in the bowl. it seems to run out of fuel in the bowl at times and the bulb does go soft.question being how to stop fuel from leakintg from around the bolt hole and what would cause it to still be leaking after changing all the gaskets."
