CANbT GET FLYWHEEL OFF
joshua
IS THERE AN EASY WAY TO GET T
IS THERE AN EASY WAY TO GET THIS FLYWHEEL OFF W/O DAMAGING ANYTHING? IT'S A FORCE 85 H.P. I'VE TRIED A GEAR PULLY BUT I KEEP SNAPPING BOLTS. PLEASE HELP W/SOME USEFUL ADVICE.
" Attach the puller (prefe
" Attach the puller (preferably a three pronged one) using a good solid set of bolts.
use a wrench to pull it down tight. Not just snug, go ahead and pull it down good and tight.
Perhaps do this after letting a little WD-40 or other penatrating oil soak in for a few hours.
after pullinkg a really good snug presure on it, back off with about a good 3lb hammer and smack the main bolt in the center of that puller about as khard as you probably feel like hitting it right about now. (go easy big guy, it aint personal) ..... but it does take a good smack.
if it dont come loose on the first smack .... hit that bad boy again. It may take a few licks but it will come off. when it does, kthere will be no doubt in your mind. It will pop, kand the puller will kgo loose.
dont be angry, but do be forceful. It is tight on purpose. Just be sure to put it back good and tight when you are finish.
Maybe someone else would like to offer the tourque specs for it. "
Just a trailer note .... the
Just a trailer note .... the "k" key on my k-board is giving me a bit of trouble. You might want to just drop a "K" now and then while reading my post.
