surfergeek411
"Hi,
I've got a fresh reb
"Hi,
I've got a fresh rebuild 4.108 in my Formosa 41. I've seen it running on the dry @ 1 year ago. I 've had it sitting in my boat but not installed. I now cannot seem to be able to bleed all the air from the system. I've got mostly new hoses etc.. I've bled from the filter to the injector pump. I can get a solid stream from the side vent screw bot can't get solid stream from the top vent screw on the Anti-stall device.
I've cranked the engine over trying to bleed the air from the last vent screw. Can the Injector pump go bad from cranking the engine with air in the system. I do get a little fuel when I crack the injectors.
Thanks,
Tim"
"Hi,
Thanks,
Tim"
