"Now that I've found you g
"Now that I've found you good folks here and see the level of advice you give, I just may have a chance to make this work - I was at a loss…
Here's some pix of the items in question:
http://community.webshots.com/album/574176694jpeoLH?vhost=community
One E235 came on the boat, a free-to-haul Sea Ox 23 console on a trailer (which was on blocks, missing a couple wheels and a hub). The guy had left the spark plugs out and the cover off for a few months in his back yard - he said it was seized when he tried to turn it. The lower unit has a crack on the side. The trim unit worked with a fresh battery to tilt engine up. This one is Serial #: J0152018, Model E235TRLCNE
I found the model list and so:
E = Evinrude
235 = HP
TR = Trim & Tilt - Sport Styling
L = Long
CN = 1982
E = "Model Run or Suffix"
The other E235 was on Craigslist. It seemed to start, run and idle very well 6 months ago on a boat in the seller's yard on the hose (but I don’t know much about big outboards). I did the compression and don't have the figures but they seemed good (maybe around 125?) and were within 5 psi, IIRC.
It has some sort of aftermarket bracket on it, and so I don't see a model or serial number plate on it. I had bought it and hauled it home before realizing its longer than the 1982 on the boat. DOH!!
The guy mentioned he had replaced one bad coil and said this about it in ad:
"1985 Evinrude 235 HP Outboard. Good running engine too big and heavy for boat. Carbs recently rebuilt, new plugs, thermostat, and impeller. $1000 obo."
He threw in an extra lower unit he had there and said was good, to cinch the deal.
Questions:
- Can I use the bracket and some parts from the 1982 engine with the powerhead and most other parts from the 1985 engine to make an engine that will fit this boat???
- Some of the bolts and nuts on the bottoms of these engines are badly rusted (maybe a third gone in size). Can that be dealt with for a reasonable amount of trouble, or should I just try to sell this whole mess off for parts or whatever?
- If I'm going to fix it, what manual should I get and from where?
I have general engine and mechanical skills and general tools, but little experience with large outboards. I've done more than a dozen carbs, rebuilt lawn mowers, a couple VW engines and trannys, and a GM truck engine about 25 or 30 years ago. And of course I've changed many an impeller over the years and pulled the head off my Mariner 40 to repair it, one time.
Any observations, advice and smart remarks on this project will be much appreciated!"
E = Evinrude
235 = HP
L = Long
CN = 1982
Questions:
