Can someone help with the Omc 800 Pressure test steps
rustymich
Thanks wondering how you press
Thanks wondering how you pressure these these Do have the low psi gauges thanks for any help..
"here is the tester, 12psi eac
"here is the tester, 12psi each drive you have 3. If it holds for a hour your good.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=270537180867&crlp=1_263602_263622&ff4=263602_263622&viewitem=&guid=fd257fd81260a075faa6d276fff9fbf8&rvr_id=&ua=M*F%3F&itemid=270537180867"
"I have a gauge to use,So you
"I have a gauge to use,So you just adapt it to the oil input holes and put 12psi on it for an
hour sounds like somethings cooking......"
Thats how i did it with a gaug
Thats how i did it with a gauge i had laying around.
Good luck and if you need more help just ask.
