" Here's your laugh for th
" Here's your laugh for the day. I removed the lower unit screw that goes through the housing and connects to a shifting component! Now I need to remove the lower unit to either try to fix it, or take it to someone who can. I am totally new at this, but USUALLY not incompetent with mechanical things. After finding this board and scouring the posts, I removed six bolts at the top of the lower unit (the upper group of six bolts). I opened the trap door and removed the lower hex screw on the shift-shaft coupler,which is now free. The boat side of the LU is pretty loose, but something very strong is preventing the prop side from seperating. What am I missing here? Thank you very much, you're really kind to help people like you do. "
