Can not hammer down throttle
afuqua
I rebuilt a 2b holly on 3.0 gl
I rebuilt a 2b holly on 3.0 gl for low speed idle problems but now I can not hammer on the throttle because it bogs down. If I idle up slow it runs just fine. Is there a simple adjustment that I could have missed in my rebuild.
Ashley
did you set the float height c
did you set the float height correctly also make sure that your mixture screw is adjusted correctly. try playing with your mixture screw first..
"Most likely an acc pump issue
"Most likely an acc pump issue. Easy to miss out the small ball-valve, even loose the ball if You do not know it is needed! A small amount of dirt in the channel/seat may even cause it to 'leak'."
I agree with the acc pump. pro
I agree with the acc pump. problem. I have relied on the seloc online man. to rebuild the carb being that I am a novice at this mechanic thing. With my GL motor it has a different float ass. and acc. pump that seloc dose not go into detail. I am going to pull fuel bowl off and tinker around hoping I get lucky and get the right setup on float and acc. pump.
I pulled the fuel bowl and dis
I pulled the fuel bowl and discovered i put the acc. pump diaphragm in backwards. Now the boat runs like a champ.
