ICantfixit
Hello, I have an old mercruiser 160 1969 engine and I believe it is an Alpha 1 outdrive, I replaced my trim pump and can not get it to bleed properly I have unhooked the lines at the hydraulics and run it up and then down etc..... but the fluid still looks really milky still and the rams will still not go in and out on there own, I have probably went through 3 quarts of oil and still will not bleed all the air out, something just does not seem right? Pump is louder than normal when I am trying to bleed this if this helps at all. Each ram has 2 lines going into it, and also this is not a self bleeding system. Thanks
