dock_holiday
"Hi, I am thinking of replacin
"Hi, I am thinking of replacing the rings in my AQ170, but I really don't have a good way to pull the motor all the way out of the boat. The boat is on it's trailer. I was thinking that if I get the motor loose from the drive and pull it forward a foot or so and roll it over onto one side or the other on top of a piece of plywood on the deck (placed under the motor to protect the deck) I could access the bottom end of the motor through the oil pan. I would be pulling and replacing the pistons and con. rods and replacing them with the motor on it's side. I currently have the head and manifolds off, and I think I would have room to do this if I remove the seats from the boat. I am thinking that 2 or 3 friends and I could man handle the motor forward and onto it's side. Any thoughts or suggestions? If this will work, which side should I lay it on? I was thinking I would put the manifold side down so I would not have to worry about crushing the fuel pump or distributor. Is this a crazy idea? Am I not thinking about some critical thing here? Any thoughts/advise very much appreciated.
Matt"
Matt"
