I have about a 1980 mirro-craft 14 deep fisherman which came with a factory matched 1980 Johnson 20hp short shaft tiller. Can I replace it with a modern 30 hp mercury long shaft tiller?
I have asked the seller to measure the distance from the transom to the anti-cavitation plate and the transom to the center of the prop shaft but I do not have the numbers yet.
I can see some potential problems navigating in shallow water which I can live with but will it lose efficiency and spray water all over the place?
How do you know how long of a shaft you can get away with??
The reason for the swap is that the old johnson is just not quite enough power to pull a tube now that my kids are bigger. Also I have overheated the Johnson and warped the head (fixed) and the prop shaft has some pits so I can't get the leg to seal anymore. (I change the oil regularly to compensate).
Any advice would be appreciated!
The boat is rated for a 35 hp.
Thank you!
Jeff
Thank you!
Jeff
