Howdy Folks,
I'm new here thanks for the help in advance.
I have a 1989 40hp johnson I pre-mix the gas and oil,
The boat was setup for premix when I got it.
Can I take the vro pump off and put a old style fuel pump on it?
If I change pumps What do I do with the plug that plugs into the vro pump?
Issues
The engine starts hard when it is cold out. (yes the choke works)
The primer bulb never gets hard. (I put a new hose assembly on, the primer bulb still never gets hard)
The clear in-line fuel filter is almost empty all the time. (it used to stay full)
The engine idles fine.
The engine runs well in the low and mid range. (up to 2800-3000 rpm)
The engine will purr all day at 3000 rpm with absolutely no problems
The engine will not go to WOT under load.
Thanks again folks,
Cheers,
Jim
Issues
Thanks again folks,
Cheers,
Jim
