I have this honda bf50 I was going to use on my pontoon before i sold it for this deckboat with the 130. Don't know anything about it hardly, have only seen it run and it's been sitting about 6 months now i need to sell it since i'm not going to use it.
It's flooding out the carbs in the airbox I think as I noticed the air box drain tube was leaking. I removed the airbox cover and a lot of gas came out, i can pump the primer bulb and when it gets stiff gas leaks out of *all 3* carbs. I'm assuming this isn't normal? And since it's all 3 and this is supposedly a low hour motor that there's some trash in the float seat or worn needle valve there or float adjustment? or could it be something worn on all 3 carbs (seems remote) they seem to leak at the same rate. Does it sound like I'm on the right track? Seeing as I can't start it, seems like it's flooding from that. Sorry i know nill about carbs except the basics.
Thanks!
Thanks!
