The engine starts and runs fairely well, but if i touch the control for the speed , i get a high power electrical shock. I have changed the coil , points , condenser, and plug wire cover and boot. And it still gives a shock.... Any ideas?
thanks to all of you for your sugestions. I will try the ground wire, to see if that is my problem . Also i did push the boot all the way in to the coil.. Thanks again joe pjoe reeves said it all........
Usually caused by a loose, broken, or non existent ground wire. I'll look thru my book to see if anything is obvious and get back to you.
+1 on the ground wire from the armature plate under the flywheel to the block. Did you push the plug wire all the way into the coil and then install the boot before you installed the coil into the armature plate?
Isn't the armature plate already grounded? It bolts onto that brass ring which encircles the top seal, wouldn't it ground through that?
Even if the mag plate has metal bushings if it has the points type ignition the groud wire is allways present.
does anyone know the procedure for replacing a water pump impeller?
Hi joe i replaced my water pump impeller, and my question to you is .,(should the engine be squirting water outof the exhaust holes on the engine.?) There is some water coming out but not in a steady stream. Thanks joe!:
On that model, it'll be just a water spray of sorts... not a steady stream.
