First here is what I have:
[h=1]1983 Johnson 7.5 hp J8SRLCTA[/h]The problem is the choke won't close or open. It's kind of mostly closed. I haven't had a good look yet. But i'm thinking one of the screws that hold the butterfly on has come off. Allowing the butterfly to get calk eyed in the throat of the carb.
I rebuilt the carb last winter and didn't touch the butterfly. (No need to.)
Here is the Million $ question. How do I get a screw out of inside the reed valve area? (Not sure it's there yet, but I'm sure its not in the breather box...) Can I shake it upside down?
The screws must be accessed for the front of the carb. Right?
How much would a screw in there mess things up? (Doesn't the fuel mix go right into the crank area...? Yikes!) Can it be stopped before it goes to the bottom of the motor?
The motor didn't have any problems up until I went to start it last week. I pushed the choke in and it didn't move. (I keep it closed at dock because of spiders....See pictures!) It pulls over fine. No sign of any foreign objects detected by pulling it over. (Yet.)
I can't seem to find any reference to screws on the butterfly on this site....?
Any direction is gladly accepted. (It's a huge pain sailing a 26' through a mooring area to get in and out of my slip!)
