Hi,
I need some help, and think you guys are the only persons that really can help me
I have a Johnson 70 Vro from 1987.
The issue is that when i took the boat in the water yesterday, i noticed that the reverse gear didn´t work. Neutral and forward are OK.
It´s grinding and won´t get into gear.
I tried to force with my finger at the "mechanism" on the enginge when my friend tried to get the gear into reverse, and it worked.
And if i tilt the engine up and tries to get in to reverse gear, it goes in without force.
But when the prop is under water, it just won´t get into gear. *strange*
Everything worked fine last season.
For notice i had a marine service company that changed the impeller recently. Can that has to do something with this?
I also tried to adjust the "wheel" at the shift cable and adjusted until it took stop.
Is the shift cable defect? Or what can the problem be.
Please help
Please help
