scott_duerring
Had a chance to get some good boating in for a long weekend. Came in Saturday from a long day of fishing... and the stb engine was running much worse than normal at idle... so, and this is after I checked the mounts the day before... so I went into the engine room and told my son to start it up and I was just looking for errant sparks... noises and the like, as well as just staring at the dang thing hoping something would jump out at me.. well it did of sorts, I was jiggling a spark plug wire and got the @#$% shocked out of me. So, shut off the engine and started making sure the wires were properly plugged in... grabbed the number one cylinder wire and the thing practically fell off of the plug... pulled it apart and the wire had become disconnected from the clamp. Re-clamped it down and put it back together and the engine idled MUCH better. I then recalled that one of the previous mechanics had replaced all of the spark plug wires, but he told me he did not have the proper Crusader wires for this engine so he made these himself. So here are the questions that came to mind, one, the cylinder that I got shocked on was not the one that fell apart... should I have gotten shocked on a properly functioning wire? Should I replace this "homebuilt" arrangement with OEM wires from Crusader? Or should I just go over each wire and make sure it is clamped down properly on the wire???
