"Bob,on 8-21 i had a post on a
"Bob,on 8-21 i had a post on a shifting problem that happens to be the same as Jeff's on 8-25. You ask me for the model # to see if it is a cone or clutch setup, here is what i got. TO766795--987797 5.7/8L. On my linkage i have just one switch which i am assuming is a interrupt switch, so does that mean there is a ESA.If i press this switch while in neutral and there is no interrupt then is it a bad ESA or bad switch. Just hard getting back into neutral while engine is running, easy when not running"
