C40TRLX Yamaha
125/124/125 comp
Carbs rebuilt, new trigger coil, charge coil, rectifier, CDI, fuel pump and filters, lines, clamps
Spark jump @ 10mm
Sparkplugs look as they should, no tell tales. Gapped at .10mm per spec
Timing at 7deg AFTC Idle, 27deg BTDC WOT. Tested for cylinder drop by running thru the range while shooting timing light looking for drop. all good
running ethanol free only high test
Motor will start and run thru 3500 rpm but tops out WOT@ 3800 rpm, spec is 4500-5000. Sluggish hole shot but not bogged down just not what it should be.
Rebuilt ignition system after stock CDI gave out, prior to that motor ran well hitting 4600 RPM, no changes to prop or damage to prop (Used test prop in same size and results the same) I should note I have a known good CDI from a test motor and results are the same
When running at 3500-3800 rpm it sounds and feels somewhat rough but not that bad, had I not known the engine I might think thats normal. Tested tach by running shop tach with same results.
I do not believe this is a fuel issue... during rebuild I ran a fiber camera to all ports we could get into and verified clean ports and I set floats to spec, set idle screws at 1.25 turns and tuned with inductive tach. Engine is also emitting a wet soot from exhaust.
My Question: All DVA readings check out as per CDI, however, when testing CDI unit (Black wires with W/Y/O stripes) I put the positive lead in my test harness and negative to the coil ground as per Yamaha Factory Manual, when I go to touch the ground a light but faintly audible spark jumps from the lead to the ground screw. Im assuming this is indicative of a loose ground, live wire making contact somewhere on the harness the coils and starter attach to or a bad coil. That said all coils in continuity as per CDI. Before I tear this apart (Again) looking for the culprit, is it normal to have a small electrical discharge when testing DVA on CDI? Only on CDI, does not happen when testing other ignition comps. (I did fire up at night looking for dancing spark, clean. also ran a screwdriver close to block and coils hoping to see a spark jump but did not.)
One other thing I noticed, when at idle I put a timing light on each cylinder, when testing #3 (Yamaha marked TDC for each cyl on the flywheel) I notice a very quick and intermittent fire to the #2 cyl, it is very fast, almost unnoticeable, if It wasnt dark and I had my readers on I may have missed it) Thanks!
125/124/125 comp
Spark jump @ 10mm
