I have a 1995 C115 Yamaha two stroke motor. It will start fine in my driveway where the motor has been sitting in the vertical position. I use the starting method in the manual (lift the lever to advance the timing, hold electronic choke, and crank the motor) and it starts up just fine.
When I trailer the boat I lift the motor and engage the stops so it is in a more horizontal position, not fully horizontal just not vertical. My ride is about 45 minutes. When I go to start the motor, after priming the bulb, it seems like it's flooded. It will not start without spraying some starting fluid. After it has been started it will start the remainder of the day. I can anchor and hang out for 2 -3 hours and the motor will re-start just fine. It seems like it does not like being in the "transport" position. Any thoughts? Motor idles and runs fine once started.
Ethan
Ethan
