Chubchaser
Just pull boat out of garage and hooked up water hose to lower unit. The buzzer went 3 or 4 beeps to let you know warning system workd. Crank motor up and now buzzer continues to beep about every 2 seconds. Water is flowing good from pee hole and can keep hand under flow of water ( not real hot). Main oil tank is 3/4 full and tank on motor is full. New oil tank cap put on due to other one had a crack in it. New water pump 2 years ago. Primer bubble isnt holding a tight prime when pumping up tight. Any help in the next direction to go would be appreciated.
