2004 Merc 115 4 stroke....... found a burned ground wire coming out of the harness going to a block ground screw, wire insulation is burned but the actual wire is ok, just exposed, runs under and around the fuse block. Motor runs fine, can't see any other damage to wireing. Question is, should I go to the trouble to dig out the harness under all the fuse block and all the stuff there to run a bypass ground wire, or just not worry about it??? I know why it happened, previous owner crossed up a + and - on the battery one time. I've already fixed the damage under the dash, just found this today.
