Broken starter bolt
been_had
I brought a 1984 king fisher a
I brought a 1984 king fisher a month ago and it has turned into a nightmare!!! Had to replace the starter upon taking the old starter off found that the bolt was broken away from the engine now i have a useless boat the flywheel has been damaged so that has to be replaced. is all lost are can the broken part be wielded back on.
"A reputable machine shop can
"A reputable machine shop can heli arc (alumium weld) the broken part back on. You would need to have thebroken piece, starter, starter bolts, and flywheel so that they can align everything properly..... starter bendix gear alignment with the flywheel teeth, etc."
Thanks Joe here's my next
Thanks Joe here's my next question this is a 1973 135hp evinrude i thought it was a 140hp i think i found a flywheel to replace the one i have it looks like the one i have but is says its a 1982 for a 140hp will it work.
"The original 1973 135hp flywh
"The original 1973 135hp flywheel part number is 581045.
The original 1982 140hp flywheel part number is 581850.
However, both part numbers supersede up to the same part number of 582628.
This being the case, I would say that they are interchangeable."
OK Joe here's the part no
OK Joe here's the part no. that's on the fly wheel that came off the motor 581044. Joe are these motors always so hard to start. It seems like its part of the reason that the fly wheel takes such a beaten from the drive are is it my inexperience.
"Start procedure..... Prime fu
"Start procedure..... Prime fuel primer bulb up hard, apply a slight bit of throttle, turn key to start position and engage choke (or primer solenoid). Engine should start and be running within six (6) revolutions.
Hard starting engine = Fouled Carburetors, Weak Erratic Ignition, Poor Compression, something of that nature.
581044 is apparently a casting number, not a part number. Not in the book."
Joe thanks again...going to ta
Joe thanks again...going to talk to someone today about wielding the broken part..also going to need a new flywheel any suggestions were i can fine a reasonable priced used one that will fit my boat.
Joe hows it going...look i hav
Joe hows it going...look i have taken every bolt lose on the crank case.. so i think
but it won't come out i don't know what else to do is there something i am missing.
Joe i don't know what its
Joe i don't know what its called.. but its the casing were the starter mounts up.. when taken apart it exposes the crank shaft are the crank bearings
