"I have a 2002 SX-m drive that
"I have a 2002 SX-m drive that I was doing some maint. on. I was greasing the gimbal bearing through the grease fitting on starboard side of transom plate when it pulled out of what appears to be a plastic tube leading to gimbal housing. The tube is now stripped and fitting will not tighten. Does anyone know if the tube can just be slide out and replace easily, or maybe get a little bit bigger grease fitting to try to screw back in?
Any help is appreciated, Thanks in advance, Joe
parts in question
