Took my boat to te lake yester
Took my boat to te lake yesterday after cleaning carbs to test . Engine runs 100 % better but no have new a problem. I made out from the dock about 300 yds and the as I began to open up throttle . The engine just reved up to high rpms and the boat would not mve any more . I may have caused this myself after removing the nut on the flywheel the other day . I tourqed it down to 105 ft lbs like i was told to do . when on the trailer with the engine off I put it in gear and spin the prop . The prop has pressure but the flywheel doesn't turn like it should with the prop. Almost like its slipping. So my question is ... Is the key in the flywheel broken or the prop?
