Broken Distributor Cap screws
rwalsh
"Hi,
My AQ125A has been lay
"Hi,
My AQ125A has been layed up for 2 years. I got the bug to reactivate it. I attempted to unscrew the distibutor cap and voila! snapped both hold down screws. Whats the best way to repair? Drill out the holes then use some kind of self-threadin screw? Also, the rotor has a number 1234 332. Any ideas what that is? Is there more than 1 disributor OEM? It came on a Renken boat,
Thanks for any help, I do wish to get back in the swing of things. Also, I wm thinking of electronic ignition.
Thx again."
"Richard, the distributor cap
"Richard, the distributor cap you need is
http://www.marineengine.com/parts/part_details.php?pnum=SIE18-5358&returntopage= 80240758.htm
and the rotor is
http://www.marineengine.com/parts/part_details.php?pnum=SIE18-5428&returntopage= 80240757.htm
Regarding the broken screws, you may be able to file the tops to make them flat, then punch them with a center punch, then drill them by securing the distributor on a drill press, then re-thread the holes. If you go that way, I wish you luck and patience, you'll need both.
Regarding conversion to electronic ignition, it will be money well spent."
"Thank you, Sir. I will order
"Thank you, Sir. I will order the parts and hopefully will get some patience somewhere. The saving grace is that I am under no pressure to get this done in a hurry.
Regarding the Elect. Ignition, any recommendations? I am somewhat of a novice in this area elec ign). I see some folks sell just the electronic ignition conversion kits (less than $50).
Thanks again, I have read with interest your postings.
Rick"
"If you manage to remove the b
"If you manage to remove the broken screws, you can simply get longer machine screws and nuts and not concern yourself with tapping the distributor. I did this on mine and it works well."
Did the nuts clear the distrib
Did the nuts clear the distributer easily? Was it a pain to get to? Did you have to remove the distributor?
Thanks a lot!
