C
Chris DePorter
Guest
"I replaced the water impeller
"I replaced the water impeller wheel last year and noticed the bolts were difficult to break loose. There was a previous owner as I bought the boat used, so I am not sure this area had been accessed before. The engine only has 165 hours on it. Recently I was running the motor and took the boat out of the water and noticed the lower houseng was coming loose. On closer look, the 2 bolts near the back of the housing were missing. I proceeded to attempt to remove the remaining 2 bolts and both broke! I thought the first 2 had vibrated loose, but on closer look they too were broken with the shaft of the bolt still in the housing. The question is what to do next. Can a machine shop drill out the bolts and retap the threads or do I buy the piece new? Please help."
