Bart Hanline
I'm in the process of replacing the impeller on my 1960 40hp Evinrude Lark II outboard and in the process of removing the bolts connecting the water pump to the lower case I broke one of them off. This is after trying the loosen the bolt with Liquid Wrench, and heat. The Seloc manual said that breaking bolts while removing water pumps is pretty common. Anyway, I tried using vise grips to grab onto the nub and this worked for one of the bolts, but the other bolt broke a second time. I was able to get a pilot hole started in the bolt but then my bolt extractor broke of in the hole. I tried drilling the broken extractor out but it just chewed up the drill bit. Now I'm in a pickle. Short of taking the entire gearcase to a machine shop, I'm not sure what else to try. I thought of coming in from the bottom up, but because of the shape of the gearcase I can't get a drill started in the hole plum. Whattttya think? Drop back and punt?
Thanks in advance!
Bart
Thanks in advance!
Bart
