Ok great. Now I understand, I think. What would happen if when you fill the outdrive with the drive in the down position until the oil flows out of the vent hole then put the plug in the vent hole and raise the outdrive ( is check valve now in the open position?) and keep pumpng oil will it then flow out the resovoir if the cap is off. Are you guys all telling me the same thing with a diferent approach.?
