sporttool1
"I have a 1995 7.4 Merc with a
"I have a 1995 7.4 Merc with a Bravo III outdrive. Last outing, last year it started accelerating prior to shifing into reverse. I've had it in twice this year to adjust the linkage and then replace the shifter cable and linkage. Here's what happens: when cold it shifts excellent, but when hot it is either very slow to shift into reverse or won't shift till I accelerate (forward gear works fine all the time). Because it shifts fine cold, but not hot, the mechanic believes that it is the hydraulic clutch assemby that is worn. He says the "upgrade kit" is $1,200 plus labor to install. Do you concur with this analysis? What other thoughts do you have please?"
