My intention to start this thread is for any and all experience with the failure of the upper gear set of a Bravo 3X outdrive, powered by a 496MAG HO for a 2005 Formula 260SS with under 500 hours of operating time. A fresh water boat, maintained very well with annual preventative maintenance and fluid changes to Mercuiser specs. Family boating usage with only occasional high RPM usage. I DID have the clutch cone replaced with OEM part the winter previous to said failure. I'll get OM Serial numbers for a future thread.
I would like to know if it's common. Which from searching many boat and Mercruiser forums, it does not seem to be common.
Also, I would like to know the 'occurance' that may have caused your particular failure, if not determined to be from 'wear'.
Any opinions (oh boy!) on the clutch cone replacement and it's potential effect on upper gear set failure.
I'll leave it at that for now and hopefully information can flow if this thread takes off.
Cheers
Cheers
