Bravo 3 streaking in water
You need to do a vacuum test also.
Why would you change the carrier assuming the pressure test passed?
Is the engine burning oil possibly?
Is it running too rich possibly?
Are your trim cylinders leaking?
Is this a closed cooling system?
Lots of other possibilities
What condition is the carrier in?
Vacuum tests are not recommended on Bravo out drives due to the design of the labyrinth style seal on the input shaft. (will not hold vacuum.)
