390Express
Got my boat out and replaced the (destroyed) propshaft seal. Once out of the water, it had gear lube pouring down the skeg. Replaced the prop shaft seal, and all is good... but, what causes the prop shaft seal failure? Is this just something that happens over time? Is it caused by a worn lower? too heavy in reverse? too much prop vibration?
Just trying to get an idea as to whether I have a bigger issue going on, or if I need to correct something going forward.
