Bravo 3 outdrives free movement
bradtv
"I have a 2004 formula pc37 wi
"I have a 2004 formula pc37 with 496ho's, bravo 3 counter rotating outdrives. I took the boat out this weekend and one prop was ventilating as I hit 3000 rpm. Props are in perfect condition, outdrives were trimmed down. As i inspected the drive units, the starbaord drive has about 8" to 12" of side to side play while the port drive was stationary and hard to move, as it should be. I had no movement of the steering wheel as I move the starboard prop. It looked as if the tiller had no movement, but still the drive had side to side play. Any idea's before my boat yard lays up the boat for repairs?"
Check your gimbal housing and
Check your gimbal housing and pin. I have a alpha one that had the same side to side action found the square pin and gimbal housing worn. Youcan replace both or do as I did that the pinand housing to a machine shop have them build the pin up to fit snug back in the housing cost 130.00. (new part replacement 650.00)
